Need Help for a 2010 Mustang Convertible issue
Old Aug 31, 2022 | 01:54 PM
Paradice61's Avatar
Default Need Help for a 2010 Mustang Convertible 4.0 v-6 automatic
I need to know where the fuel pump driver module gets its power from?? Any troubleshooting advice would be greatly appreciated. I am having fuel system problems and this is about the last thing that is left for me to look at. it doesn't seem to be getting power
when I tested the connection
Thanks in advance
Old Sep 1, 2022 | 11:04 AM
Check if there is power coming to the inertia sw and power going out to the driver module.
Old Sep 1, 2022 | 03:41 PM
Paradice61's Avatar
There is no power to the inertia switch. The fuel pump driver module has a brown wire with white stripe and it has a very dim light when the power is on and that is the only wire that has power while checking with test light.
Old Sep 1, 2022 | 06:32 PM
There is a fuel rail pressure sensor that tells the PCM if there is the correct pressure for demand. If not, the pcm gets a signal from the fuel pump driver module and adjusts driver module power on time according to demand. It sends a pulse width modulated signal to the driver module.Depending on demand , if no demand no or very little power is sent to the driver module.
Your best bet is to get hold of a good manual and learn just how this system works. Some folks have supplied constant power to the FPDM just to get home.
Old Sep 2, 2022 | 02:49 AM
raski's Avatar
The inertia switch is upstream from the FPDM. If you have no power to the inertia switch, you need to start looking upstream towards the fuel pump relay and the wiring/connectors in between.
tcjhkbjt
May 14, 2015 12:01 PM
Sergiowoods
Nov 1, 2010 06:10 AM
bigu
Jul 27, 2009 08:44 AM
junglebrother
Jun 11, 2009 09:52 AM
SpeedChannel
Dec 17, 2008 03:00 PM
