need help w/vibration
I have a 2002 ford explorer sport that vibrates but has I go faster vibrations tends to go away have changed out rotor/pads & inner & outer bearings//// also seems to still slightly vibrate when stopping.....all parts were brand new OEM replacements any help would be appreciated....
Guessing that your Sport is a 4x4.
Here’s a list of other possible causes for front-end vibrations:
Worn wheel bearings
Worn king pin bearings
Worn tie rod ends
Worn out steering damper
Misaligned drive shaft(s)
Worn drive shaft(s)
Damaged drive shaft(s)
Worn Transmission/transfer case mounts
Misaligned transmission/transfer case
Recent suspension lift
Larger tires
Tires out of balance/lost weight(s)
Tire with broken/shifted belt
Uneven tire wear
Warped rotors
Worn pinion bearings
Worn transfer case bearings
Diff or transfer case flange(s) out of round
Worn wheel bearings
Worn tie rod ends
Worn drive shaft(s)
Larger tires
Uneven tire wear
Warped rotors
Luke Hopkins
Jan 19, 2014 01:15 PM
BigRig Mechanic
Feb 26, 2009 06:12 PM
