No heat new parts.
Old Jan 6, 2014 | 06:21 PM
Neobreaker's Avatar
Default No heat new parts.
Well basically long story short is my heat went out in my 91 ford ranger 3.0 so i changed the thermostat that didnt fix it, changed the heater core that fixed it but then the next day my water pump went out so i changed it and now once again i have no heat. and the temp gauge doesnt even move.
Old Jan 6, 2014 | 07:59 PM
Our first curiosity is could the thermostat you installed be defective ? If the heater hoses don't get hot after it runs for 10-15 minutes I would remove the thermostat and see if it is closed completely. If closed place it in a pot of water heat the water and watch it to see if it opens and closes when the heat is removed and the temp goes down. If all that checks out at least you are reasonably sure the thermostat is OK. It should be a 195 degree thermostat.
Did you compare the water pump to the one you removed ? They should have been identical, impeller housing etc. Could you have possibly moved the wire from the temp sensor where it is not making a good connection? I've given you some checks to make , let us know what you found .
Old Jan 6, 2014 | 11:29 PM
Use Common Sense's Avatar
Did the thermostat have a bleeder hole in it? If you have air in the cooling system, the heater core is the last place air usually resides and takes a while to burp out. Air in the heater core results in no heat. Temp gauge no moving is also a symptom of air in the cooling system. Without a bleeder hole in the T-Stat, air will set at the back side of it and keep is from reaching opening temperaure. ROBERTSHAW T-Stats will normally have the bleeder hole.
Old Jan 7, 2014 | 07:44 AM
Neobreaker's Avatar
the day i changed the thermostat i had heat, that night is when the water pump went out, I'm not familiar enough with the thermostat to tell if there is a bleeder hole but on one of the hoses to the heater core does have a cap thing on it.
Use Common Sense
Jun 25, 2016 01:30 PM
redman26
Jan 14, 2013 05:08 AM
bigmudder77
Sep 28, 2008 03:37 PM
DJSkiddlez
Aug 3, 2007 07:36 PM
whoyourdaddy49
Feb 11, 2007 07:45 PM
