No O2 sensor listed in the FSM. WT?
Old Nov 22, 2020 | 10:48 PM
bradleyheathhays's Avatar
Default No O2 sensor listed in the FSM. WT?
Have an '02 Taurus that just rolled over 100k so I'm looking to change out all the O2 sensors before the weather gets too cold. I go to look up oxygen sensor in the old FSM to see what this is gonna look like and I can't find the term 'oxygen sensor' listed anywhere. Not in either the Fuel System or Exhaust System sections or in the back index. The closest it's referenced in one of the two previously mentioned sections is something like a 'catalytic monitor.' And nowhere can I find the procedure for changing them out.
Am I missing something here?
Old Nov 23, 2020 | 05:30 AM
Good Morning !
It has to have an O2 sensor for each bank. Just follow the exhaust from the heads on each side of the engine down to the converter after which there should be at least one O2 sensor.
If you are considering replacing them all, for what it is worth, purchase Motorcraft sensors , preferably from Ford, then you should be assured of getting the correct sensors.
There are aftermarket sensors that will do the job, unfortunately not all come with the right connections. Learned the hard way, save yourself some trouble.
rlevy64614
Jun 30, 2020 06:39 PM
john doe
Jun 23, 2013 07:06 AM
forthvacav
Jan 15, 2009 09:35 PM
devilbunny13
Nov 8, 2008 05:02 PM
Landry24
Oct 4, 2006 07:54 PM
