o2 sensor location
Old Nov 8, 2008 | 10:26 AM
devilbunny13's Avatar
Default o2 sensor location
yes unfortunately I have more questions... on the 02 explorer sport... my check engine light came on... was told o2 sensor may be out but was told there was 4 of them on my vehicle. I found 2 of them but cant find other 2... is it normal for a vehicle to have 4 o2 sensors... thank you for any info...
Old Nov 8, 2008 | 05:02 PM
techford's Avatar
Default RE: o2 sensor location
Hi,yes it is normal to have 4 O2 sensors. Two heated oxygen sensors and two monitor. There is one before, called the upstream, and one after the catalyst, called the downstream. On your specific truck, if I remember well you have three. One because each catalyst on each side of the engine (this part is called a Y-pipe. After the y-pipe there is twoin-line catalysts and there is one monitor between these two.
But, before replacing part for no reason, I suggest that you have, at least, your code scanned if you don't want to pay for the whole diagnoctic. The we will be able to pinpoint your problem.
Nic
johnsonsnb
Dec 6, 2006 01:07 AM
jimmyb63
Nov 17, 2006 02:17 AM
rickbraley
Oct 5, 2006 03:12 PM
04Ranger4.0
Oct 12, 2005 12:18 PM
gmm
Jul 22, 2005 11:09 AM
