OVERHEATING HAS ME LICKED!
Old Sep 9, 2006 | 09:16 PM
BIBBER's Avatar
Default OVERHEATING HAS ME LICKED!
77 302 Ford overheaating. Replaced thermostat....new higher pressure radiator cap..,Flushed out radiator, flushed out engine block....swapped old water pump with new High Performance Edebrock.. still overheats...top and bottom hoses pressurize hard as rocsk but bottom hose remains cool? overflow tank perculates... any ideas on what I'm missing.........
Old Sep 9, 2006 | 09:39 PM
goon's Avatar
Default RE: OVERHEATING HAS ME LICKED!
I worked on a 76 1 ton with the same problem turned out to be the wire was making contact with the block it would not happen all the time. Also make sure the rad cap is okay.
Old Sep 9, 2006 | 11:32 PM
94 4x4 ranger's Avatar
Sounds like it may be a bad head gasket.[hr]Exaust getting into the coolant.
Old Sep 12, 2006 | 12:09 AM
sean08's Avatar
If there's moisture in the spark plugs, it could be a blown head gasket that's causing it. Check also for possible leaking intake manifold and anti-freeze.
Old Sep 18, 2006 | 11:13 PM
a1934fordcar's Avatar
save yourself some time and get peace of mind. Go to NAPA and get head gasket tester. It test for exhaust gas in the coolant and that sounds like it might be your problem.
askedofgod
Jul 18, 2015 11:53 AM
Hawk
Nov 15, 2013 08:05 PM
imjustanumber
Apr 18, 2005 12:36 PM
Cwzanth
Nov 25, 2004 06:10 AM
warren
Oct 22, 2004 05:19 PM
