PLEASE HELP 6.4 knock after heads replaced.
Old May 20, 2018 | 01:51 PM
Dock's Avatar
Default PLEASE HELP 6.4 knock after heads replaced.
My 6.4 is knocking and smoking. Just had the heads replaceds and the mechanics dont know what it is.
Link
thanks ryan
Old May 20, 2018 | 02:28 PM
Heads were OE/reman or replacements? Who’s gaskets? Bolts or studs?
You have a pressure gauge installed,, is it over pressurizing the coooling system, puking coolant from the degas or out of spec pressures/temps on a hard pull? Sounds like on initial start, it maybe hydro locking a bit..
Old May 20, 2018 | 03:23 PM
Dock's Avatar
Brand New heads, race studs and gaskets not sure which brand. The gauge is for the fuel pump on a different problem that i had where when i was pulling a hill it would die. This knocking happens after its hot, its not as bad if the truck is cool. Could an injector be leaking when i turn off the truck? I will check and see if im low on coolant.
Flounder35
Jan 16, 2018 08:28 PM
mustang fox
Dec 14, 2015 01:36 PM
67plymouth
Dec 28, 2011 05:12 PM
