problems on start up
Old Aug 28, 2005 | 04:28 PM
97ranger's Avatar
Default problems on start up
I have a 97 ford ranger and the problem started a few months ago,when i start up the motor will not rev up to normal. It stays at a very low idle infact it will stall some times. Then after a while it heals it self for a few weeks. Does it worse when its cold. The garage checked the cold engine sensor and says its good. Im lost. Any help would be appreciated.
Old Aug 29, 2005 | 03:49 AM
Ramrod48's Avatar
Default RE: problems on start up
, Well first I would get a new GARAGE GUY !!!!!!, Sounds like the IAC , Idle Air Control Valve,,, Most times you can get away with just taking them off an cleaning them with a lil carb. cleaner, Just spray them out a bit get most of the black goo outta it, Also spray some where it mounts on the side of the throttle plate in the holes to clean them out , An it's good to clean the throttle plate itself if it looks nasty. I know they got that lil sticker that says NO-NO, If that dont work then you most likely have a wiring problem. Theres a slight chance your PCV is plugged up, There Cheap like $5.00 bucks if you should wish to replace it. Heres a web site for you , come on back an lets us know what you found ,
http://www.autozone.com/servlet/UiBr...3d800b98f5.jsp
Old Aug 29, 2005 | 03:09 PM
cctxfish's Avatar
No, if its dieing because you open the throttle up a lil then, I'm guessing something like TPS, or MAP/MAF. but, cleaning the IAC can only help
makuloco2000
Oct 22, 2013 09:46 PM
mayor
Nov 18, 2012 06:46 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
iownslaves
Apr 1, 2008 06:03 PM
Ranger96
Jan 27, 2007 06:18 PM
