taurus
Old Jun 28, 2011 | 09:17 PM
970401ford's Avatar
Default taurus
I have a 2001 taurus.. Runs great. When it gets hot outside and i run a few errands.. It wont start after i shut it off a few times... The fuel pump will not kick on.. After it sits for 10-20 minutes it will fire back up and run great... Any suggestions?
Old Jun 29, 2011 | 05:44 PM
way2old's Avatar
Possibly a fuel pump relay. If it gets hot, it may open and not close back until it cools. You can swap it with another one that is the same size and see if it helps. Use one that controls something you do not use a lot.
Old Jun 29, 2011 | 06:21 PM
970401ford's Avatar
i bought a new relay.. and it did the same thing.. so i swapped the old one back in and it still wouldnt start back up.. had to wait still.. Id hate to replace the fuel pump and have it not be the problem..
Old Jun 30, 2011 | 06:22 PM
970401ford's Avatar
could it be the whole fuse box? I dont want to spend money to replace the fuel pump and have it still doing the same thing.. The relay is usually extremely hot when it wont start.. Then i put a new one in and it still wouldnt start for 10mins..
Old Jun 30, 2011 | 06:27 PM
way2old's Avatar
Maybe check the grounds to the fuel pump to see if there is rust or corrosion on a connection. That will cause a restriction for the current and could cause the relay to heat up. Good luck.
Old Jun 30, 2011 | 08:13 PM
greasemark's Avatar
Have you checked the fuel pressure when hot? These fuel pumps were garbage when they were new, as I replaced about 5 a day when they were new. If you have a code P0191, that's the proof. I'd be that if you verify the fuel pressure is not at least 30 psi when KOEO, then forget the wiring and look at the pump. You could check the fuel filter, but if it's been a while, it probably needs to be replaced with the pump. This is a classic vapor lock concern.
Lars(wi)
May 29, 2013 07:22 PM
blixx003
Apr 11, 2007 11:05 AM
blixx003
Aug 14, 2005 03:42 AM
