temp gauge problem
Old 03-25-2007, 11:40 PM
carp's Avatar
Default temp gauge problem
I have a 97 f-150 4.2. When the temp gauge starts to increase the amp and oil gauges top out. When it reaches full temp., the temp, amp and oil gauges bottom out. I replaced the sensor but that did not help the problem. Any clues on what the problem is.
Old 03-26-2007, 02:07 PM
goinstrong's Avatar
Default RE: temp gauge problem
With electrical problems it's good to always start by cleaning battery cables and checking fuses/fusible links. Next I'd look for an antifreeze leak (antifreeze conducts electricity and shorts things out when splashed around - wash/wipe dirty wires under the hood). Next I'd check sensors and I'd look for a crossed wire or a problem in the dash cluster. Could also be a computer problem.
goinstrong's Avatar
Or if you have an electric fan - could be fan relay.
Old 03-26-2007, 03:44 PM
carp's Avatar
Thanks for the info. when I get a chance I will try your suggestions.
Old 03-31-2007, 07:01 AM
enibum's Avatar
Do your lights get brighter when this happens? It could be a voltage regulator problem.
Old 04-01-2007, 07:31 PM
goinstrong's Avatar
That's sounds right. Voltage regulator affects a lot of electrical items in the basic accessory scheme of things. Starter circuitusually remains normal, etc. and electrical systems go crazy.
l2rocku2
01-05-2009 11:30 PM
adam11082
10-02-2007 08:36 PM
Jhurst
06-30-2007 04:00 PM
Quick Reply: temp gauge problem
