Transmission problem?
Old Nov 20, 2012 | 01:45 PM
fedford's Avatar
Default Transmission problem?
I have a 2001 Escape with the 3L V6 and automatic trans, it has 110K miles. Lately I have noticed when driving on the highway and starting up a hill, the car kind of shudders when it makes the first downshift. Is there something I can or should do before taking it to a trans shop?
Thanks for any help you can offer.
Old Nov 20, 2012 | 04:40 PM
I would suspect it is ether rough coming out of overdrive or the torque converter is not disengaging as smoothly as it should. It could be a trans related problem . One thing you can try is to stop at a place like Autozone or another auto supply store where they will check the vehicle's computer for any history codes. They usually will do this free of charge as a customer service. If you have any codes in there it hopefully would narrow down the system that is having the problem.
If they find any , get the number(s) and post it/them here. That is very possibly what any shop would do first anyway.
Old Nov 20, 2012 | 09:09 PM
greasemark's Avatar
Have you checked the fluid level and condition? If it's just a little low, it could respond this way. Check it hot, idling, and in park.
Old Nov 23, 2012 | 01:31 PM
fedford's Avatar
I should have said that the fluid level is good and the fluid is clean.
Old Nov 24, 2012 | 05:56 PM
bluewind's Avatar
I would make sure the engine is properly tuned. If something is even slightly out of whack the ECM will raise the idle a little and that could have an effect on the way the transmission shifts.
tom2005
Aug 16, 2005 01:27 AM
bisne
Aug 14, 2005 05:58 PM
jmbetts
Sep 15, 2004 04:28 AM
