What is that clicking noise?
Old Dec 1, 2011 | 06:52 PM
995jim's Avatar
Default What is that clicking noise?
96 escort 1.9L: what is the clicking or tapping noise coming from around the intake manifold & fuel rail which is also causing only 3 cylinders to run & occassionally only 2 cylinders to run.The clicking increases as the RPMs increase and is more prevalent under a load as acceleration from a stop. items replaced: fuel regulator, coil pack, plugs & wires. Any help would be greatly appreciated. Thanks, jIM
Old Dec 2, 2011 | 09:47 AM
bluewind's Avatar
Listen tot he fuel injectors using a stethoscope or a piece of hose. Listen near the valve cover for lifter noise. Use a noid light to check the injector wiring. Check the timing belt.
Follow the trouble shooting section in the Haynes manual.
Old Dec 2, 2011 | 12:49 PM
cougar_fan's Avatar
How can you tell you have three or two cylinder running?
Old Dec 3, 2011 | 05:28 PM
995jim's Avatar
well I simulated the engine symptoms by pulling 1 plug wire as it seems hardly noticeable but 2 wires pulled really reveals a rough running engine. since my original post the car has left me stranded as it stalled at a stop sign and initally it acted like the starter was froze. The battery is good and after 10 minutes it decided to crank over but not even fire. So I trailered it home and havent had a chance to investigate. What are symptoms of a bad crank sensor? thanks jim
Old Dec 3, 2011 | 07:27 PM
cougar_fan's Avatar
No spark during cranking, because the ECM has no idea when to fire, so it doesn't fire at all. If CPS dies on you, so does the engine - instantly.
Old Dec 4, 2011 | 04:52 PM
995jim's Avatar
well i had a few minutes to do some diagnosis and it sparks but wont do any more than that. No start just turns over.fuel pressure is 40 with ignition on and while cranking drops to 25 . any ideas on proper fuel pressures? thanks jim
Old Dec 4, 2011 | 05:43 PM
cougar_fan's Avatar
On my V8 4.6, the fuel pressure after the pump primes the system is 40 PSI, and drops to 32 PSI when the engine idles. If you speed up, the fuel pressure goes up to about 34-35 PSI (wide open throttle). 25 PSI should be good enough to get some fuel in. Are your injectors opening? Listen to them (or feel them, they should be clicking as they pulse)
Old Dec 4, 2011 | 09:29 PM
greasemark's Avatar
I'd bet this is just a blown engine. Escorts run just like this when they die. Usually, it's because a piston comes apart.
I'd start with a compression test. VEry simple, Very determining for this problem. Fix the base problem, and most if not all the symptoms will go away.
Old Dec 23, 2011 | 05:37 PM
995jim's Avatar
I think your right,I put a wratchet to the crank and as I cycle the engine it has a jam spot with the spark plugs removed. jim
Old Dec 23, 2011 | 11:02 PM
greasemark's Avatar
Sorry if I was right in this case. Looking on the bright side, these engines were easy to pull and repair.
You shouldn't have any problem with it.
Merry Christmas to all!
mark
Malibu Barbie
Dec 14, 2006 07:46 PM
kasady
Aug 9, 2006 07:57 PM
kasady
Jul 28, 2006 06:45 PM
steveandbelinda
May 9, 2006 11:29 PM
pamolnar76
Sep 15, 2005 06:52 PM
