White Display Screen?
Hello. I have a 2016 Ford Fusion SE and while driving earlier today the LCD screen went all white with radio and tuning still working. How can I get this fixed? It has about 26K miles in it but I do not have warranty anymore, just the Power Train.
Depending on how handy you are and if you can do a little of your own work.
I was interrupted and didn't get back till now.
If you would like,
You could remove both battery cables from the battery, hold the 2 cable ends together making good contact for a few minutes.(10)
then reconnect them , positive first then negative.
You will lose all memory sets and need to reset your radio stations, power seat memory and any other features that are placed into memory.
You will also need to drive the vehicle some to allow it to adjust to your driving habits. It's a pain, but if it solves the white screen problem only you know if it is worth the trouble.
If you would like,
If you would like,
If you would like,
As you know sometimes with your own personal computer , sometimes you need to shut it down and allow a reset.
Anytime the battery is disconnected from a vehicle , it loses it's adaptive memory.
You don't need to do any adjusting ,the vehicle's computer does this.
It is called a forced reset and is used to sometimes get rid of gremlins.
I don't believe it is a fuse problem , and the only way to answer your question about charges is to call Ford yourself and ask them.
By using a battery disconnect, it forces the systems to “re-initialize “ or reset. Anytime the battery is disconnected it erases the vehicles “keep alive” memory and all stored info will be lost like hanky mentioned. This includes vehicle ‘learned’ driving strategy, so some minor differences may be noticed until your personal habits are re learned.
So,, when the car is started, are you seeing the FORD logo/splash screen?
Sometimes when the unit is having glitches, you can do a Master Reset from the screen Settings list, but without being able to view the screen features, battery or audio unit power interruption is the first step.
The other thing to try would be a Bezel Diagnostics test. During the test the unit would do a speaker walk around test (we know the audio is working) as well a screen display indication of the speaker position as it’s tested.
If none of these attempts show any screen activity, it would be either a display screen issue, or possibly the APIM module on the back of the screen..
So try this,,,
If you have a CD player.. press and hold the EJECT button, and within 1 second press and hold the SEEK UP button. The test should begin.
If no CD.. simultaneously press and hold the steering wheel SEEK UP switch and audio units TUNE UP button. Test should begin..
Any visual results?
So try this,,,
Any visual results?
So try this,,,
Any visual results?
So try this,,,
Any visual results?
You shouldn’t need a video..
The battery is easily located,, then just remove the negative cable. Either cables,, will interrupt power distribution and cause initializing.. After the interruption, if still a blank screen, do check for ‘any’ screen activity with the diagnostic steps listed above..
