1997 f150 trailer wiring
Old Dec 31, 2012 | 07:38 PM
john evans's Avatar
Default 1997 f150 trailer wiring
I bought a 1997 f150 ext cab with 8 ft bed . It has wires for trailer hook up but the plug has been cut off. It looks like it is factory wired in . Any help would be great.
Old Jan 1, 2013 | 10:15 AM
If you have or have access to a test lite or multimeter all you need to do is check each of the cut off wires. Once with the parking lights on once with the left sig on , once with the right signal on and once to determine which one is the ground wire.
It;s quick and easy just make a note of which color wire is for which function and reconnect the replacement plug/wires with shrink butt connectors and you're done.
Old Jan 1, 2013 | 11:12 AM
Left Turn Yellow
Right Turn Dark Green
Trailer Battery Orange
Running Lamps Brown/White
Back up lamp Black/Light Green
Brake control Dark Blue
Ground White
Old Jan 1, 2013 | 09:30 PM
john evans's Avatar
thanks i will try that .do you know if there was a trailer brake with that setup or or would it be wired to original brakes?
Old Jan 2, 2013 | 05:38 PM
way2old's Avatar
The blue wire should be the trailer brakes. If it is full electric brakes, you will also need a brake control box. Surge brakes should work without a box.
Old Jan 4, 2013 | 10:48 AM
john evans's Avatar
i can not see were a brake control box was prev installed . not sure how they did it.
Old Jan 9, 2013 | 03:53 PM
john evans's Avatar
can anyone tell me how many fuses and were they are located for the turn signals for the trialer wiring. any help please.
Old Jan 9, 2013 | 05:00 PM
way2old's Avatar
Try this.
Old Jan 9, 2013 | 06:36 PM
john evans's Avatar
thank you i will try this.
rdandcc
Nov 15, 2011 09:04 AM
93f250xlt4x4
Jul 3, 2008 10:02 AM
pkeck
Jan 16, 2007 08:37 PM
Spade
Jan 1, 2007 03:45 AM
jakec8
Dec 3, 2005 02:26 PM
