2007 explorer Eddie Bauer abs
Old Mar 4, 2022 | 08:03 AM
H82work1's Avatar
Cool 2007 explorer Eddie Bauer abs
All information I find for tone ring is on rear I’m sure my ring for front is built into the hub assembly is this correct rock auto shows ring. What should I order tks
Old Mar 4, 2022 | 12:46 PM
Not a good idea to suggest what you should order based on insufficient info.
What is the original problem?
If you are going by a particular code, what was the code?
Need to be careful because codes do not always indicate a defective sensor and , don't know if you can return a part ordered for refund or credit if necessary.
Keep in mind a code only tells you what system is involved and hopefully provide some direction. Maybe we can help save you some $$$.
EddieOwner
Mar 11, 2022 12:01 PM
fryguy
May 22, 2018 02:44 PM
pjhmah
Feb 12, 2013 12:58 AM
christurner
Oct 15, 2012 03:50 PM
mustanggt
Nov 20, 2008 06:58 PM
