2007 F-150 2wd hub assembly, can only find 4x4
Old Apr 25, 2023 | 11:42 PM
Nesto23's Avatar
Default 2007 F-150 2wd hub assembly, can only find 4x4
Checked my front wheels, the passenger side has vertical play. Been humming for a year and going quiet on right turns. Tire is becoming thinned and vibration is noticable now. Using VIN to look up front wheel hub assembly but I'm only being shown assemblies for a 4x4 when it's not. To add to my confusion, I searched for the part part while not using the VIN and being told that the 4x4 won't fit. This is my first truck and manual transmission so if I'm just ignorant to the knowledge then somebody please tell me. Don't want to take it to shop.
Old Apr 26, 2023 | 01:31 PM
You may not need to take it to a shop, but you might consider checking with a Ford Dealership Parts Dept.
Give them your VIN and people complain about them charging a little more, but look at the aggravation you went through so far, and you would be done by now.
Do it once and do it right.
Old Apr 29, 2023 | 03:09 AM
Nesto23's Avatar
Can't argue with that. Looked up Ford authorized parts and services. Immediately found correct rotor and hub with abs ring. Not much more at than what I was going to pay (probably for the wrong part). Thank you. 👍
Old Apr 29, 2023 | 12:42 PM
Thank you for the update
boggsjlm58
Jun 1, 2019 08:48 AM
coldvalley
Feb 9, 2010 07:11 PM
jzink04
Sep 9, 2007 09:49 PM
JoeV
Apr 8, 2007 09:37 PM
tigertom
Feb 14, 2006 09:02 PM
