2014 F150 4X4 Front End Problem
Old Nov 1, 2015 | 06:51 AM
Opsguy's Avatar
Question 2014 F150 4X4 Front End Problem
My 2014 F150 4X4 is wearing the front tires very unevenly by cupping the tires across the tread. No problem with wear on either edge of the tires, just the cupping across the tread. The dealer says it is because I didn't rotate the tires often enough. They were rotated at 6,000 and now at 18,000. Front end alignment was also done at 18,000 (present mileage) with "minor" adjustments being made. Anyone else having these type tire wear problems?
Old Nov 1, 2015 | 07:53 AM
This does not have to be the problem with your vehicle, but have seen where defective shocks allowed the tire to bounce going down the road producing the cupping result.
Old Nov 3, 2015 | 08:13 AM
Opsguy's Avatar
Thanks, Hanky. I fully agree - I'm no tire expert, but after been driving for over 50 years, I don't recall tire cupping being caused by misalignment. I believe alignment problems usually cause excess tire wear on either inside or outside of tread. Bad shocks or out of balance tires would cause or allow tire bounce, cupping the tires. I will monitor the tire wear (like a hawk) on the front tires after this rotation and will be back with the dealer at the first sign of cupping on the tires!
Old Nov 3, 2015 | 02:50 PM
Just a reminder, now that the tires have cups worn on them no matter where you place them (like the rear) all the surfaces will wear the same and the cups will just get deeper with miles.
Bigdog36
Nov 17, 2014 07:41 PM
jeffswav
Jun 8, 2011 07:42 AM
anwalt
Oct 9, 2010 04:42 AM
bmarnall
Aug 15, 2009 07:10 AM
bssfiler
Nov 2, 2007 01:03 PM
