Car won't start after radio instal.
Old Mar 22, 2020 | 11:13 AM
Kellen's Avatar
Default Car won't start after radio instal.
Car won't start after radio instal 2014 Ford Focus. .took it into a shop got a touchscreen stereo worked the whole first day. The second day went to turn the car on and everything came on but the car. Radio lights windows all worked. But car just was clicking like it wants to turn over but never does. Any ideas on this ??
Old Mar 22, 2020 | 01:58 PM
Welcome to the site..
’clicking’ like meaning low voltage?
Some of the electrical features will be disabled during a cranking attempt, but sometimes if watching headlight output, ‘then crank’, if the headlights dim, horn output is now weak, the battery state is usually low.
Quite a few of the panel indications, windows ect don’t require large amounts of current, cranking the engine does..
Have you tried jumping it?
Battery original?
Old Mar 22, 2020 | 06:08 PM
Kellen's Avatar
Battery original?
got a code reader plugged into it 3 codes for low fuel pressure so guessing fuel pump is out. Luckily should be covered by warranty. Weird timing with the stereo. Lol
Old Mar 22, 2020 | 07:52 PM
“Clicking” not sure how that would be directly related to fuel delivery..
People use the term ‘won’t turn over’ or what you mention “wants to turn over but never does” which would lead most to think the engine will not ‘crank over’ meaning turn/spin the engine over. Generally if the engine cranks over normally without an engine start up, better to use those terms so we’re all on the same page.
What sounds suspect is,, after the new audio unit install, the unit continues to draw voltage over night drawing the battery down. With a low battery, many system lights and windows may still operate if the battery has some charge left. With that,, a low battery will quite often cause relays to ‘click’ or rattle in the instrument panel during a cranking attempt. Low voltage can also cause invalid codes to be generated..
But if you car cranks over fine, with a no start condition, chances are the battery is fine although it approaching the end of its service life if it hasn’t already been replaced. And if an aged OE battery, reserves tend to be less for issues like leaving lights on, or extended radio play times, including normal allowed system draws etc.
Do keep us updated on the fix, hopefully under warranty
Old Mar 22, 2020 | 08:08 PM
If I might,
that vehicle has a CAN system(Controller Area Network) and it is very likely the radio is one of the modules in the network
If the original radio is removed and another is substituted that is not compatible with the network it can interfere with network operation which can include starting problems and network communication problems.
How much trouble is it to remove or disconnect the add on appliance and see if starting takes place, just a suggestion.
Michael Work
Nov 23, 2018 04:28 PM
Sophie Elizabeth
May 17, 2017 09:35 AM
robertabf
Nov 10, 2010 07:31 PM
tdknott
Feb 17, 2008 03:39 PM
trekman
Jan 26, 2006 07:38 PM
