Engine problem
Old Mar 30, 2016 | 03:57 PM
betbil's Avatar
Default Engine problem
2006 Mercury Montego when started, it won't rev past 1800 RPMS. When I put in drive it bogged down and died. This started when driving it.
Have put in new fuel pump and filter.
Old Mar 31, 2016 | 06:17 AM
Might be a good time to check for a plugged converter. Any rough running , misfires lately?
Old Mar 31, 2016 | 01:39 PM
Alanah_Rae's Avatar
agreed with you hanky. You have to check the plugged converter bcz this type of happened come when plugged converter is not working well !!
Old Mar 31, 2016 | 02:00 PM
betbil's Avatar
Thanks, There was no problems before. Was driving down road about 45 and it just lost power, slowed right down to a stop.
Old Mar 31, 2016 | 04:10 PM
If the engine quit just like you turned the key off, would suspect something electrical.
If on the other hand it loses power more and more , it could be electrical , but I would be inclined to suspect a possible fuel starvation problem. A mechanical problem could also give similar symptoms, but we have to start someplace. To throw something in for good measure a poor electrical connection/supply for the fuel pump system kinda gets into the picture too.
Old Apr 13, 2016 | 04:35 PM
Alanah_Rae's Avatar
Well said hanky agreed with you !!
Old Apr 21, 2016 | 05:05 PM
betbil's Avatar
hooked a meter up. Code is PO463, Fuel level sensor circuit, high voltage.
Old Apr 21, 2016 | 05:19 PM
I would suspect the vehicle has a poor ground connection for the fuel pump and level sending unit. You would need to check the ground connections right from the tank unit to wherever the ground wire goes ,most likely to a ground coming off the sheet metal or frame. Common problem where fuel pump quits working , gets replaced when all along it was a poor connection . They should always be checked before condemning a fuel pump.
amcole82
Feb 11, 2011 08:18 AM
jamesmanning
Nov 3, 2010 10:49 AM
Bill in Tampa
Apr 27, 2008 09:30 PM
bmwrocks03
Apr 21, 2008 09:29 PM
daveranger
May 24, 2007 12:56 PM
