Need advice installing an engine
Old Mar 23, 2011 | 08:31 PM
Ford1st's Avatar
Default Need advice installing an engine
I'm trying to install a engine in my 2001 explorer, the converter seems to be seated properly in the transmission, however I cannot seem to get the engine to seat all the way to the transmission housing. The flywheel bolts are aligned and go through the flywheel, but that's as far as I can get it.
Old Mar 23, 2011 | 11:51 PM
If you are trying to install an engine that is not an exact replacement, same year same model etc., the hole in the flywheel could be a different size , the converter tangs might be different if you are not using the original converter with the original trans and on & on. Ford is known for making production changes mid year and one little item could be different. I would make sure the converter is all the way in to engage the pump gear fully.
gtram
Aug 15, 2013 09:13 PM
Elitegeek
May 31, 2012 11:36 AM
kooter07
Dec 28, 2006 11:19 PM
Tacoma750
Dec 27, 2006 06:17 PM
kooter07
Apr 9, 2006 07:16 PM
