Need help with led headlights
Old Mar 4, 2019 | 06:59 PM
David Clay's Avatar
Default Need help with led headlights
So I bought a used 2018 Ford Edge titanium and for one it does not have fog lights so it has regular halogens with the led/hid style headlights so I ordered a new led kit now I have them installed the passenger light works fine stays on and driver side after about 2 minutes just cuts off and this is on auto btw I can turn the switch to on and it comes back on and then turns back off please can anyone give me an answer or some help
Old Mar 5, 2019 | 05:14 PM
You should have received a load resistor for each lamp. It sounds like one of them is opening up and opening the circuit to the lamp. I know it is extra work, but if you can switch the load resistor from the working side to the non working side and see if it solves the problem. If it does, get in touch with seller and maybe you can work something out.
Eddie Rivas
May 30, 2018 11:06 PM
Bryan Debnam
Jun 24, 2017 05:44 PM
Cordell Scott Nicholson
Jul 5, 2013 06:22 AM
pythonwill
Jun 11, 2013 08:42 AM
jmedeiros40
Mar 15, 2010 04:36 PM
