power steering pump still makes noise
Old Apr 19, 2023 | 11:53 AM
Fordtransit2016's Avatar
Default power steering pump still makes noise
hi there
i have a 2016 ford transit 150 with 226000km and just replaced the power steering pump. The van still makes that whinning noise but not as much as before
what can the problem be still?
Old Apr 19, 2023 | 07:20 PM
Did you perform the steps to get all the air out of the system?
Old Apr 19, 2023 | 07:47 PM
Turning the wheel left to right several Times
also changed the o ring which is connected to the pump
mechanic thinks the other o rings need to be changed
Old Apr 22, 2023 | 06:17 PM
If you can , suggest you get a second opinion, from another shop.
Old Apr 23, 2023 | 05:35 AM
raski's Avatar
What fluid was used for the refill?
Old Apr 23, 2023 | 06:08 PM
Mechanic said ATF
Old Apr 23, 2023 | 06:43 PM
He did use power steering fluid? ATF not power steering fluid?
Old Apr 24, 2023 | 04:34 AM
raski's Avatar
Originally Posted by Fordtransit2016
Mechanic said ATF
Make sure Mercon LV transmission fluid meeting Ford's spec WSS-M2C938-A was used for the refill.That is what Ford calls for.
Old Apr 24, 2023 | 07:02 AM
Ok will do
thank you
jjaws44@hotmail.com
Jul 14, 2011 10:32 PM
pearglace
Dec 29, 2008 12:28 AM
dave404
Mar 24, 2008 11:45 PM
tdrn
Aug 30, 2007 07:32 AM
strider380
May 20, 2006 11:10 PM
