Rear window problems
Old Mar 24, 2009 | 07:29 PM
BBlack's Avatar
Default Rear window problems
How is everyone today.I have had my F-350 Super cab since 2003 and this is the first problem I have had.My rear window goes down but will not go up ( from the back or from the drivers side). I got a new relay for both sides but it still does not work. Would this problem be a ground or the motor itself.Hope someone can help...Alberta is still cold even in March and now I havee to drive my Wifes Dodge....Thanks
Old Mar 25, 2009 | 06:00 PM
way2old's Avatar
Have you removed the panel to see if there is current going to the motor with switch in the up position? If there is current at the motor, then the motor is bad. Use a test light to check for current.
epford
Mar 19, 2008 11:09 AM
capleton456
Sep 13, 2006 10:01 PM
DRP2000
Mar 16, 2006 09:35 AM
fords
Nov 3, 2005 10:50 PM
Modified
Apr 4, 2005 03:09 PM
