replacing low (service port)A/C hose on 06 Taurus
Old Jul 3, 2019 | 09:10 PM
Jim Casparis's Avatar
Angry replacing low (service port)A/C hose on 06 Taurus
I'm trying to replace this hse on my Taurus but can't figure out where connections are
Old Jul 5, 2019 | 02:25 PM
You might try the following,
Either a Ford Dealer Parts dept or maybe an aftermarket auto parts supply store, see if they have the hose assy , go look at it and if you need it then purchase it and now you will know where it goes and can be separated for replacement.. There are some special procedures you need to follow when replacing this part and if you are not equipped for this type work, might be a good idea to get an estimate or two and then decide how you want to handle the job.
Old Jul 6, 2019 | 12:11 AM
Default thanks
That's a great idea! I ended up replacing the low pressure service port instead & thought I'd fixed the problem as it held a charge for a few hours but tonight it quit blowing cold again and I'm at a loss as to where the leak is. Have ordered a vacuum pump & gauges that will arrive Monday.
Old Jul 6, 2019 | 09:13 AM
It might be a good idea to consider replacing the receiver/dryer while you have it apart.
Reminder; you will need to also replace some of the refrigerant oil lost, sounds like you have a pretty good idea what to do , be sure and be safe !
Genson
Jul 1, 2019 03:38 AM
tvest@canyonconnect.com
Jun 18, 2015 04:32 AM
Colt Hero
Dec 28, 2008 11:26 AM
spike19
Jun 29, 2008 01:04 AM
rlevy64614
Nov 8, 2007 01:20 PM
