timing wont crank
Old Dec 2, 2017 | 03:36 PM
Dodgeman's Avatar
Talking timing wont crank
2000 zx2 someone please help any info . is there more than one mark on crank pully i must not be right . no compression on 2 an 3 have spark, gas .
Old Dec 2, 2017 | 05:13 PM
What did you do that you wound up with no compression there?
Old Dec 3, 2017 | 02:09 PM
Dodgeman's Avatar
yes hanky i did a comp. test cant fig out whats going on i have cked timing mrks made sure cams were algn. crank mark on tdc .whas next maybe headgasket?
Old Dec 3, 2017 | 05:43 PM
When I inquired about what did you do I was referring to what mechanical work. Did you do any work with the cams etc.? There is more going on here that I need to know before offering any hopefully useful suggestions.
Old Dec 3, 2017 | 06:21 PM
Dodgeman's Avatar
Default zx2
yes sorry . the only thing i did was before i removed the old belt was put on tdc. cams were off took belt off set cams locked them down put new belt on was same no crank cked comp . there i found low comp in 1 an 4 none in 2 an 3
Old Dec 4, 2017 | 02:33 PM
It should be a non interference engine,
when you went to set everything did you confirm that #1 piston was on the top of it's compression stroke? If not start all over and you must confirm #1 IS AT THE TOP OF COMPRESSION STROKE, otherwise the timing mark will appear at TDC, but a different cyl will be at the top of comp stroke. (Sounds like timing could be 180 degrees off)
lwayfan
Oct 24, 2010 09:55 PM
SAMF
Oct 3, 2010 07:20 PM
stackedstroker1
Mar 30, 2009 06:33 PM
mbates19733
Feb 11, 2006 02:44 PM
