Generator light in 1964 f-100
Old Jul 12, 2020 | 03:08 PM
Max Williams's Avatar
Default Generator light in 1964 f-100
My generator light slowly comes on when ever im at an idle or push in the clutch. I checked the voltage of my battery while off and running and the voltage is good and the generator is charging the battery.
Old Jul 12, 2020 | 03:21 PM
scott.butler4's Avatar
Have you checked the battery voltage while the generator light is on and while it is off?
The alternator can have a internal fault in the control/sensing circuitry and still output the correct voltage.
Your truck is to old for any info to be listed on the Ford site so I cant see how the internal wiring works.
Old Jul 12, 2020 | 04:40 PM
I’d be curious as to idle/cruise voltage too.
Make sure the idle speed is spec as well.
My old Rambler would suffer a flicker/dim gen light at idle , and adjusting the regulator a tad cured the issue..
jcjhl69
Apr 17, 2013 05:49 PM
teddysmith1952
Jan 8, 2010 12:38 AM
sk8terswife
Apr 9, 2008 02:59 PM
seanny77
Dec 26, 2006 10:48 PM
