Intermittent Vibration/Shake
Old Apr 20, 2013 | 07:26 PM
erldprl's Avatar
Default Intermittent Vibration/Shake
I have a 1968 Ford Galaxie with an automatic transmission and a 428, I never had a problem before, we rebuilt trans and motor and now at high speeds I have a problem with a shake or vibration that starts then stops starts then stops from around 45 mph to any higher speed it just amplifies, any ideas???
Old Apr 21, 2013 | 09:30 AM
grindman's Avatar
First off welcome to the sight. Is the vibration in the steering or in the seat? there's a whole bunch of things that can cause shaking in a car at high speeds.this will just help narrow it down to the root cause
Old Apr 23, 2013 | 03:37 PM
erldprl's Avatar
Most of the vibration is in the seat.
Old Apr 23, 2013 | 03:39 PM
erldprl's Avatar
By the way thank you for the greeting it good to be on.
Old Apr 26, 2013 | 09:53 AM
grindman's Avatar
if I remember right that car has the old FMX trans. in it cause of the shape of the hogs head or the old C-6 they were round and didn't look like the ones out of the late seventies even though they pretty much had the same innards. the shaking could be coming from the drive line like a bad u-joint or a slightly out of balance driveshaft. next question is when the trans was rebuilt did you have it done at a shop or did you do it yourself?
Old Apr 27, 2013 | 10:01 AM
erldprl's Avatar
Default reply
I had the transmission rebuilt at a shop, it is a C6 it was a FE car with a C^ in it, I am tending to think it is the drive shaft, I will do the repairs to that first and let you know, thanks for the input.
Luke Hopkins
Jan 19, 2014 01:15 PM
grease_monkey1965
Apr 26, 2008 09:07 AM
jkmf250
Oct 12, 2007 07:46 PM
BlindFordUser
Mar 18, 2007 02:55 AM
SixSigmaRacing
Feb 3, 2006 10:33 PM
