Weird leak
Weird leak
I have a 2009 Ford Focus SE. Manual Transmission. Bone stock, no upgrades no nothing. I was changing my serpentine belt this past Saturday and at first noticed the green liquid next to the (bad) sway bar bushing. Then I noticed (circled) the black tube with coolant very very slowly dripping out.
When i I turn the car on, nothing happens. When I turn the heat on, it starts giving signs that there is air coming out (such as the liquid wiggling or wanting to come out) which leads me to believe it is some kind of air vent and the liquid may possibly be some kind of overflow safety? Any input is appreciated. If anybody knows what this is and can help me diagnose the problem I would be very grateful.
Thank you 😊
Welcome to the site.,
It a heater core leak, the coolant is leaking from the AC/heater evap box drain..
Should have read the year ,, and looked a little closer !
What your seeing is the bright green dye that’s in the refrigerant/oil. The evap core is most likely leaking.. If you touch and rub it on your fingers, you’ll notice it’s oily. And with a size able leak, you’ll have no A/C, or soon to be..,
