Sights 'N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Ford's, Racing (Street/Strip), Interviews, and Off Topic.
Weird leak
Old Mar 26, 2019 | 02:12 AM
Roger92's Avatar
Default Weird leak
I have a 2009 Ford Focus SE. Manual Transmission. Bone stock, no upgrades no nothing. I was changing my serpentine belt this past Saturday and at first noticed the green liquid next to the (bad) sway bar bushing. Then I noticed (circled) the black tube with coolant very very slowly dripping out.
When i I turn the car on, nothing happens. When I turn the heat on, it starts giving signs that there is air coming out (such as the liquid wiggling or wanting to come out) which leads me to believe it is some kind of air vent and the liquid may possibly be some kind of overflow safety? Any input is appreciated. If anybody knows what this is and can help me diagnose the problem I would be very grateful.
Thank you 😊
Old Mar 26, 2019 | 09:19 AM
Welcome to the site.,
It a heater core leak, the coolant is leaking from the AC/heater evap box drain..
Old Mar 26, 2019 | 02:01 PM
Roger92's Avatar
Will this mean I have to drop the dashboard in order to get to it? Is it the heater core itself or is there other components causing this leak?
Thank you you for your reply!
Old Mar 26, 2019 | 04:04 PM
Should have read the year ,, and looked a little closer !
What your seeing is the bright green dye that’s in the refrigerant/oil. The evap core is most likely leaking.. If you touch and rub it on your fingers, you’ll notice it’s oily. And with a size able leak, you’ll have no A/C, or soon to be..,
bradleyheathhays
Dec 17, 2018 01:03 AM
mcminnvilleguy
Jul 1, 2012 12:37 PM
dlutz1983
Oct 8, 2008 04:07 AM
alldonein
Dec 13, 2007 06:48 AM
kpmc1206
May 8, 2005 05:10 AM
