South West AZ, TX, NM, OK
trans. fluid cooler 360 cu in.
Old Apr 18, 2023 | 08:45 AM
ray77's Avatar
Default trans. fluid cooler 360 cu in.
'68 ford f240 360 cu. in. v 8 engine. This engine has an transmission fluid cooler that looks like a small radiator. Was wondering, to save space in the engine bay, does anyone make a different type of cooler that maybe can be installed on the frame rail? Also if something is installed on the frame rail, would it interfere with a power steering pump?
Old Apr 18, 2023 | 09:08 AM
You won't get the desired cooling if mounted out of the air stream.
That is why they are placed below the radiator..
Maxacosta93
Jul 31, 2018 04:18 PM
primem
Jun 16, 2015 10:25 PM
qtband
Aug 5, 2012 03:52 PM
AMMO
Oct 2, 2007 03:26 PM
frenchman
Mar 11, 2007 05:08 AM
