clutch pack direct drive
Old Jul 14, 2019 | 09:31 PM
Michael Troy Smith's Avatar
Default clutch pack direct drive
i am an allison builder and am building a ford aod for a buddy i took five steels and five frictions out of the direct clutch, using a transtar kit to rebuild it that came with all new steels and frictions 5 an 5 dont fit back in it only 4 and 4 do is this normal
Old Jul 16, 2019 | 06:26 PM
You might want to check with Transtar. Sometimes they will include in a kit parts for a std duty and parts for a heavy duty, depending on which you happen to be working on.
Old Jul 16, 2019 | 09:31 PM
Not certain on the Transtar, but if the stack is count reconfigured or thicknesses changes from OE, re-confirming total stack height and snap ring thickness adjusting may be needed for spec clearance..
Old Nov 11, 2019 | 01:56 AM
mmerlinn's Avatar
AOD transmissions came from the factory with two different thicknesses of plates. Drums changed according to the plate thickness. Seems like the plates you got from Transtar are the wrong plates for your drum.
80-early 83 cast iron drums used 0.80" frictions.
Late 83-up cast iron drums used 0.62" frictions.
All stamped steel drums had larger diameter frictions.
Old Nov 11, 2019 | 02:01 AM
mmerlinn's Avatar
80-early 83 cast iron drums used 0.080" frictions.
Late 83-up cast iron drums used 0.062" frictions.
This post is corrected from previous post. Tried editing last post, but edit function does not work.
smacelroy
Nov 22, 2014 05:06 AM
grindman
Jul 19, 2013 09:56 PM
heretic
Sep 17, 2012 06:34 PM
speedfever22
Apr 15, 2007 02:55 AM
giczei
Feb 18, 2005 10:02 PM
