2001 Windstar Will Not Stay in Park
Old 09-01-2018, 12:18 PM
CBirnley's Avatar
Default 2001 Windstar Will Not Stay in Park
1. The vehicle rolls when placed in park, as such the e-break is being used to hold it in position.
2. The column shifter is loose, to the point where it is hard to determine what position the transmission is in, ie. in Drive I or II or Neutral, etc.
3. I will be replacing the Neutral Safety Switch as the vehicle does not start unless it is in the Neutral position.
Was wondering what else could be causing the two issues (numbers 1 and 2 above) as previously mentioned. Thank you for any guidance.
Old 09-02-2018, 02:44 AM
What you might do is check if the excess slop in the linkage is due to looseness in the shifting linkage up inside the steering column or in the cable and those parts that go down to the transmission.
Once you determine which area it is you can check further for loose, worn or broken parts.
Old 09-02-2018, 09:51 AM
CBirnley's Avatar
Thank you for the insight - I will def give this a try.
Joseph Windsor
01-17-2019 10:09 AM
aclark
09-07-2011 11:28 PM
seehofer
05-31-2010 04:15 PM
E350turbodiesel
05-07-2009 02:39 PM
Snip931
01-15-2009 10:14 PM
Quick Reply: 2001 Windstar Will Not Stay in Park
