2000 Windstar engine shaking
Old Feb 1, 2019 | 05:09 PM
mechman81's Avatar
Default 2000 Windstar engine shaking
Shakes while sitting idle and gets worse at 1.2K RPM but clears up at around 2k+. Pulled each injector and each cylinder is firing. No codes. Motor mounts and harmonic balancer looks fine. I'm down to balance shaft and flywheel or torque converter. How do I check those without tearing down the engine? 3.8 SEL
Old Feb 2, 2019 | 04:46 AM
Could be a problem with the EGR syst and plugged ports
Old Feb 2, 2019 | 08:19 AM
mechman81's Avatar
Keep seeing people mention the EGR, but never considered it to be the problem. I had the intake clam shell off a month ago and made sure all the EGR ports were clean. The only thing I can think of that would cause this is the EGR valve being stuck open. I will check it today and post back thanks.
Old Feb 2, 2019 | 08:32 AM
Any check eng lite or codes?
Places like Autozone will check for any codes at no cge. Can you try this, if so post the code(s) here . might be able to get some direction and go from there.
Old Feb 2, 2019 | 08:55 AM
mechman81's Avatar
I vacuum pumped the EGR valve and it stalled the engine, so it works and there are no codes. I ran a mode $06 and it came up with several fails, but nothing significant. I can post those if you'd like but I don't think they're related.
Old Feb 2, 2019 | 04:25 PM
When you say shakes, does this mean it is possibly misfiring >
Could you be a little more specific?
If you are not sure, place your hand back at the tailpipe . If you feel a puffing , it is misfiring.
Old Feb 3, 2019 | 08:31 AM
mechman81's Avatar
No, it is not misfiring at all. I checked each cylinder and all of them are firing. I think my problem may be the link listed below.
https://www.justanswer.com/ford/11e3...ts-bounce.html
Old Feb 20, 2019 | 01:08 PM
mechman81's Avatar
It was the harmonic balancer.
Old Feb 20, 2019 | 01:58 PM
Thank you for the update .
DJ40
Apr 15, 2015 03:51 PM
fordwoman99
Mar 3, 2013 05:24 PM
AKEscape
Feb 12, 2008 01:32 PM
chaud
Apr 12, 2006 02:14 PM
kspencer
Feb 7, 2005 09:53 PM
