ABS module?
Old Jul 13, 2018 | 03:05 PM
  #11
12characterz's Avatar
Ok Im replacing the rear axle assembly in a couple weeks, its parked until then.
When thats done Ill go to one nearby and try my luck.
If I wanted to bench test the wheel sensors in the meantime, any suggestion how Id go about that?
Old Jul 13, 2018 | 05:42 PM
  #12
The only thing you can measure is continuity. It will be either open or closed.
A good scan tool or graphing meter can provide the info you would need to determine which wheel , if it is a wheel sensor, is causing the problem. Once that is determined, you would concentrate your efforts on that area.
atrdriver
Jun 28, 2024 01:35 PM
bhmorrill
Mar 2, 2013 07:54 AM
mrcarter9760
Aug 9, 2011 10:40 PM
paddygfw
Nov 24, 2010 08:33 PM
