engine locked up again!!
Old Jan 12, 2012 | 08:59 PM
blazz81's Avatar
Default engine locked up again!!
I have a 2001 windstar 145k..
in the last 6 months i had this problem with the engine starting,,
is would get stuck and i would have to spin the engine backwards a few times to get to spin enough to start,
in 6 months it did it 3 times,
it would sound like the battery was dead but its a new bat..
it would go WOW-WOW-WOW-WOooo stuck, i could only spin it backwards..
SOOO today i get up to go to work and it did it to me... it took over a hour to get it started BUT this time the engine has a clunk clunk clunk when i start it,, it sounds like its from the lower end but im not sure..
any one out there have this problem b4?
what could it be?
Old Jan 19, 2012 | 12:11 PM
bluewind's Avatar
Metal hitting metal. Not a good sign. Maybe the flywheel came loose or a connecting rod broke, or something else really nasty.
Those are all guesses based on your description.
blue
Old Jan 19, 2012 | 12:25 PM
It could also be that darn flexplate connecting the engine to the trans. Probably broken.
Trans has to be moved/removed to repair.
Old Sep 30, 2012 | 09:55 AM
Stoopalini's Avatar
Did you ever figure this out Blazz81?
My buddy has a 2001 Windstar doing the same thing. Loud clunk when trying to start it. We manually rotated the engine with the crank bolt, and can get it to rotate a bit, but then gets stuck on something.
We removed the front valve cover and see the pushrods moving when rotating by hand, so it's not the timing chain. Only thing I can figure is either a lower end failure, or most likely a flex plate issue. But before dropping the transmission, I'm wondering if you ever got your issue fixed.
Thanks!
W00t625
May 23, 2012 07:11 AM
63unibodyf100
Jun 9, 2006 03:27 PM
chaud
Apr 12, 2006 02:14 PM
berok
Dec 29, 2005 02:38 AM
Smitty
Jan 15, 2005 10:59 PM
