Factory wiring question
Old Aug 10, 2013 | 10:53 PM
Monty51's Avatar
Default Factory wiring question
I have a 2001 Windstar that didn't come with cruise control. I'm wondering if anyone knows if they came with all necessary wiring for options such that I could install a used steering column with cruise controls and have that feature.
Am I off track on thinking this could be possible?
Thanks
Old Aug 11, 2013 | 04:07 AM
The controls on the steering wheel are only part of the system. There are the parts that connect to the engine, stoplite system and so forth. It's not impossible, but a lot of work and additional parts required. Not usually a recommended change.
Old Aug 11, 2013 | 07:20 AM
Monty51's Avatar
That makes sense.
Thanks, I think I'll leave it alone.
Old Aug 11, 2013 | 10:58 AM
You could always add an aftermarket cruise kit, much easier and less cost then trying to go OE..
Old Aug 12, 2013 | 07:05 AM
Monty51's Avatar
I looked into a couple of aftermarket kits and wasn't sure about them. In hindsight, they'll be easier than trying to retrofit to factory specs.
Old Aug 16, 2013 | 01:32 PM
Use Common Sense's Avatar
Check with your local Ford Parts guy. If they have been around long enough, they may know. I remember a few years ago that Ford offered Cruise control as an accessory for people that wanted cruise control on a non-cruise control vehicle. The accessory consisted of a Plug-n-Play steering wheel with buttons. Only difference between the the two was you didn't have a tilt steering wheel on the accessory unit. It isn't offered anymore since pretty much everything has cruise nowadays. You may find out that the factory cruise wheel may be Plug-n-Play.
Old Aug 17, 2013 | 07:20 AM
Monty51's Avatar
Well that would be nice. I'll give them a ring.
Thanks!
wrocky
Sep 21, 2012 08:17 AM
lsalogistics.com
Feb 23, 2008 12:55 AM
kevlapp
Jul 26, 2007 08:55 PM
dee004
May 10, 2007 09:06 PM
penny
Feb 7, 2005 11:30 PM
