I need help (vibration)
Old 08-25-2015, 12:42 AM
KSA2010's Avatar
Originally Posted by primem
you found old oil on a new coil you just installed?
about the coil what i mean by its new, i changed before around 4-5 month thats why i said is new,
now i found on coil#7 at top only old oil i dont know from whereother colis doesnt have any oil totlay clear
  #12
Old 08-25-2015, 04:52 AM
Looking at the front of your car, on the driver's side, coil #7 is the 3rd one back. If you remove that coil and spark plug ,switch it with anyone even on the same side then see if the misfire moves to the new location. If the misfire moved to the new location just switch the coil to another location . It's easier to swap coils than plugs. Depending if there is any change with the location of the misfire it is now pinned down to one cylinder.
If the misfire is where the old coli was placed, it's the coil, if where the old plug is placed it's the plug, if still at cyl #7 there may be another problem not necessarily the injector. Now it is time to have a compression check done. If that comes out OK then you could go after the injector or it's connections. Pulling the fuel rail off just to check injectors is a lot of work and can create more problems if new "O" rings are not installed.
There is always the possibility of an intake manifold vacuum leak.Since you don't have access to a decent scan tool you need to go this route.
  #13
Old 10-08-2015, 09:33 AM
KSA2010's Avatar
Thanks for your help
Luke Hopkins
01-19-2014 01:15 PM
BigRig Mechanic
02-26-2009 06:12 PM
devilbunny13
03-18-2008 06:17 AM
dtk11
05-19-2005 04:01 PM
dtk11
05-03-2005 05:37 PM
Quick Reply: I need help (vibration)
