2010 F250 leaking
Old 08-19-2016, 07:39 PM
Bam's Avatar
Bam
Bam is offline
Default 2010 F250 leaking
I have a 2010 F250 with a sun roof and when it rains it leaks in my truck from the light. I have changed the sunroof seal 2 times and it still leaks. Need help
Old 08-20-2016, 03:39 AM
Pretty sure there are drains provided at the corners. Make sure they are clear all the way down so the water can drain off the channels.
Old 08-22-2016, 05:31 PM
PSD-BLACK-CLOUD's Avatar
Do you have cab lights?
Old 08-22-2016, 07:44 PM
Bam's Avatar
Bam
Bam is offline
Yes and waters leaks from the cab light and sunroof control area.
Hanky is there a way to check the drains without taking the head liner down.?
Old 08-23-2016, 03:58 AM
A couple of things you can try,
Blowing some compressed air through a piece of small hose that will fit into the rear corner drains will dislodge the junk accumulated in there and drain out the bottom or
try inserting a piece of plastic type cord (weedwhacker) string and carefully push it through the drain hose to push the debris out the opening.
Michael Leonard Woodcock
12-10-2012 08:36 PM
acopswife
10-22-2012 12:48 PM
1Tucker0
06-27-2012 01:18 PM
tech6761
01-04-2011 12:20 PM
Quick Reply: 2010 F250 leaking
