Transmission shift problems
Old Jul 17, 2018 | 03:50 PM
Gil's Avatar
Gil
Default Transmission shift problems
Took car for test drive after new rubber installed, this is the first time the car has been on the road for some time. 63 Fairlane 260. Previous owner said transmission was no original and somewhat new. Got to take their word sometimes. I have not changed the fluid, it looks clean and full. Starts out fine and when shifting to next gear, it's automatic btw, it seems to wind up and then shift. It does not do a hard shift, just seems like the gears slip and then they catch. Any ideas? Does this sound like internal problem? Thanks for any feedback,
Old Jul 17, 2018 | 06:15 PM
This goes back a bit, but I believe that trans used Ford TYPE F fluid which had a different friction coefficient from type A. If the wrong fluid was used it raised heck with the clutch friction material and bands. It also gave mushy shifts.
If you are not sure what is in the trans presently, might be a good idea to install the correct fluid . For some reason if type F was installed in other transmissions (Not Ford) all it did was provide abrupt shifts , but no damage. I believe some racing folks took advantage of more positive shifts and used Type F.
Old Jul 18, 2018 | 09:25 AM
Gil's Avatar
Gil
I definitely do not know what type of fluid is in there or how long it's been in. I may give your suggestion a try before taking it to a shop.
Thanks hanky.
Old Jul 18, 2018 | 09:31 AM
Vacuum modulator possibly...
Old Jul 18, 2018 | 09:53 AM
Gil's Avatar
Gil
I don't have a lot of experience with transmissions so I just googled what the modulator does and it seems like that may also be a good part to check/replace. New fluid and modulator may happen this weekend. Thank you Hayapower.
Old Jul 18, 2018 | 11:11 AM
Generally when a mod fails, when you remove the vacuum line there will be trans fluid present. Also make sure there’s a good vacuum supply to the mod.
If dry, you can always pull a vacuum on it prior to a replacement to check ops..
Old Jul 23, 2018 | 05:07 PM
Gil's Avatar
Gil
This Sat I took out the modulator and found I had the wrong part, I need the push in type and I had thread type. New one is on the way. Question, a pin about 1" long came out when I removed modulator, I searched online to find out what this was. When reinstalling, do I put pin into modulator hole and install together or do I put pin in first and then modulator? Seems like it would be easier to do together, as I don't know how far pin needs to go inside transmission. Thanks.
Old Jul 23, 2018 | 05:46 PM
I found it worked best when I put the pin in the modulator.
Old Jul 24, 2018 | 05:40 PM
Gil's Avatar
Gil
Thanks hanky, I'll have a chance to install on Friday or Sat, let you know how it goes.
Old Jul 31, 2018 | 11:04 AM
Gil's Avatar
Gil
Default Almost there
Replaced trans fluid with type F and new modulator. Car ran a way way better. I still need to play with adjustment screw but I think the modulator was the issue. Thanks for the advice.
SuzySpecter
Dec 6, 2016 08:55 PM
skully_68
Aug 16, 2013 05:20 PM
lakeseed
Aug 13, 2012 06:12 AM
mws0019
Aug 7, 2009 01:18 AM
Exploder4.0
Oct 5, 2007 06:27 PM
