Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Bronco 2 no spark
Old Sep 6, 2010 | 04:51 PM
richdrums's Avatar
Default Bronco 2 no spark
Hi;
I was wondering if the 88 bronco 2 I have has a distributor pick-up in the distributor , I seem to have gas but no spark.
thank rich
Old Sep 6, 2010 | 06:21 PM
What engine do you have in it?
Old Sep 7, 2010 | 06:41 AM
richdrums's Avatar
Default no spark
I have the 2.9L.
thanks for your help
Old Sep 7, 2010 | 08:40 PM
I need to look and check based on the info, will get back to you!
Old Sep 8, 2010 | 03:38 PM
Does your distributor have a TFI module mounted on it or is it mounted separately from the distributor? In either case there is supposed to be a hall effect switch in the dist. This provides the PIP, profile ign pick up signal to the module. Let me know which system you have and I will try to help you determine if it is working.,,,,,,,,hanky
JCtrayer
Nov 22, 2011 10:07 AM
Rogerseric
Aug 12, 2011 12:34 PM
noonrock
Jan 13, 2009 09:00 AM
67comet
Jan 1, 2007 02:47 AM
Loum12
Mar 12, 2006 09:09 PM
