Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Codes P0102 and P0340 keep coming back...Help!
Old 09-21-2014, 09:27 PM
smb1206@hotmail.com's Avatar
Unhappy Codes P0102 and P0340 keep coming back...Help!
Okay, I have a 1998 Ford Contour with a 1997 engine put into it. It is a four cylinder, and the same codes keep coming back every once in a while.
Over a year ago, I replaced the MAF sensor (code P0102) and I did the camshaft position sensor for the second time about 4 months back (code P0340).
I don't believe that these parts are just going to keep on going bad all the time, and I assume that something else is making these parts go bad, or just making them malfunction so that the computer thinks they are bad.
Here are the symptoms:
1. Sluggish acceleration always.
2. Engine sometimes bogs down between 50-55 mph.
3. On one occasion, all the dashboard lights came on, and then flashed back off. This happened at the same time as the RPM's going up on their own and then back to normal. This recently happened when the car was just started up, and hadn't been driven yet.
Any help is greatly appreciated! Thanks so much!
Old 09-22-2014, 07:37 PM
Something you can try,
Unplug the plug on the alternator and test drive the vehicle. If the problems disappear , replace the alternator with an OEM rebuilt from Ford.
Alternators when malfunctioning can send voltage spikes into the elec syst and drive the computer nuts.
Suggest a Ford remanufactured alt because many aftermarket alternators come with problems which you really don't need or want.
IHMan
02-14-2015 06:37 PM
GStevison
02-24-2011 05:35 PM
vardslane
10-08-2009 09:10 AM
gskills
03-21-2008 10:01 PM
bud121156
06-27-2007 12:10 PM
Quick Reply: Codes P0102 and P0340 keep coming back...Help!
