98 crown Vic ac vlutch
Old Jun 23, 2019 | 09:41 PM
Robert Fraley's Avatar
Default 98 crown Vic ac vlutch
I checked the bearing, and that is fine.. The clutch works, but it has like rust on it.. I cleaned it and put it back on.. But it still makes a whine noise.. The AC is cold.. the back pully is fine..is the clutch worn out?
Old Jul 5, 2019 | 05:15 AM
raski's Avatar
The whine likely is from the compressor.If the system is cooling, I would leave it alone.
Old Jul 5, 2019 | 08:35 AM
Compressor clutches don't usually make any noise when engaged. If the bearing is on it's way out , you will hear the noise when the clutch is not energized.
If the noise is getting worse, I would suggest having the noise confirmed before it destroys the compressor and debris gets into the entire system .That can be quite
expensive to correct.
twj815
Oct 15, 2014 03:59 AM
spatterfree
May 5, 2014 08:45 AM
dan rap
Jun 14, 2010 06:05 PM
dosnotches
Jan 7, 2009 01:37 PM
anthonyspeltz
Sep 20, 2005 04:16 PM
