High beams seem upside down
Old May 20, 2016 | 12:51 PM
biggyfries's Avatar
Default High beams seem upside down
I bought a 2007 cop car at auction and I am enjoying it a lot--its a low-miler in real nice condition. One little problem--I drove out of town for the first time recently (at night) and the low beams seemed pretty normal, but when I tried to use high beams, the light actually got dimmer, but seemed to shine brightly four feet in front of the car. Hi-beam indicator works fine, but no hi-beams. I assumed the bulbs were at fault, so I bought two new bulbs and there is no difference at all, high beams still are dimmer. I thought something was installed upside down or something--nope--everything is installed right, there is no way to get anything installed 'wrong'--I just have a mystery, something someone here may know something about I hope. Suggestions?
Old May 21, 2016 | 04:32 AM
biggyfries's Avatar
When the car was stripped of its police equipment, could wires have been clipped which disabled the hi-beams? Where would I look for such a clipped wire? There are bundles of wires all over this car.
Old May 21, 2016 | 09:22 AM
Thumbs up
If you put a meter on the connector, what voltage does it read? If spec voltage, I'd probably add a test ground there and see if it corrects the lamp output. If a power distribution wire was cut, probably wouldn't have lights, a ground issue may cause the lights to dim. Cut, left loose etc. Could be a hazard/visability system, or part of that was left in place as noted. If you need help with connector views or ground locations, let me know..
Old May 23, 2016 | 10:41 AM
primem's Avatar
my dads 88 cv had the same issue. I know its a completely different build so this may not apply....for his there was a wiring harness swap for the headlamps.
Old Oct 27, 2016 | 03:40 PM
biggyfries's Avatar
Here I am months later still without hi-beams. I don't drive on the open road much these days so it isn't a crippling problem, but would still like a solution. Could it be as simple as a bad multi-function switch (turn signal lever)?
If I buy another turn signal lever and hi-beams are still not working then there is no returning it. How would a smart guy proceed?
Old Oct 27, 2016 | 05:51 PM
I believe the police vehicle had what are called wig-wag hi beams that went through an alternating relay. The possible reason for the dim hi beams now is probably because as Hayapower stated , what is operating in the hi beam position is now using the hi bulbs for a ground. I believe Use Common Sense may have some idea what and where they installed the relay or harness. I have installed them in various emergency vehicles ,but never in a CV. It would require a wiring diagram to try to pick out possible locations where they could have done that.
If they had strobes also installed in the front it may require a wiring harness as primen stated.
Old Oct 28, 2016 | 07:29 AM
biggyfries's Avatar
I think you're right hanky, there were strobes on this car and they were removed. I am weak on electrical analysis/repairs so I may have to hire a pro to sort this out.
rs4 tony
May 15, 2014 03:13 PM
Abarylak
Apr 27, 2014 07:20 AM
tach
Aug 27, 2012 05:38 PM
weighman
Jul 8, 2010 02:02 PM
dmac30
Apr 13, 2009 01:35 PM
