new here with no crank problem
Hello all new here with a annoying problem that started yesterday. I have a 04 grand marquis/crown victoria. I went to go run a few errands and it started up like normal. Then i realized i forgot some thing inside so i shut it off when i came back out within minutes it would not crank start tick or anything. So i started off checking battery and terminals but still nothing i then started checking fuses and relays i even picked up a replacement starter solenoid relay with no luck so i pulled the starter off and took it to get tested and it passed. From there i started trying tips and suggestions i found online with no luck until i found out i could remove the starter solenoid relay turn the key to the on position and jump pin 87 and 30 and it started fine and ran fine. So at this point i thought it might be the ignition starter switch so i picked one up this morning installed it and still nothing. Now i am wondering if it might be the neutral safety switch but from what i have read on various forums if that is the problem it should be able to start in neutral. i am at a complete lost here and hope some one can lend some insight into this situation. thanks for reading
thanks for the reply its raining now and i have no dry place to test with a test light/ multimeter. but i did try the suggested tips of checking if the reverse lights switch on which they do and pressing the break and trying it in neutral position with no success
sales@HOBD2.com
obd2 diagnostic tool supplier,honest obd2 HOBD2-Honest OBD2 Diagnostic Tool & Auto Scanner Supplier
Hayapower
Jan 1, 2012 05:32 PM
dcbridgers
Oct 3, 2009 09:14 PM
dragbike425
Jun 5, 2009 10:45 AM
