02 e250 w/ light issues
Old Dec 4, 2013 | 12:00 PM
  #11
No worries..
H/L switch connector meaning the main headlight switch.
Power distribution for the park/run lamps is out of vans interior CJB on fuse F2.10 (20amp) From the fuse panel,, power s/b 'Hot at all times' on the tan/white wire on the headlight switch connector. It's a fairly simple circuit for park lamps, so if there's no power there it gives a direction to go,, back towards the CJB, or, if 12v is out of the switch on the brown wire when park/head is selected, then look more towards harness/connector etc. issues.
The circuit (F2.10) shares a loom/circuit splice with the multi function switch for headlights function but since the headlights 'seem' to be working correctly I'd say the power is there. But with no park/run lamps the H/L switch connector test would prove out the fuse and the CJB as a quick test for a functioning power current in/out to the H/L switch for the park lamps.
If the power is there, and you rotate the H/L switch to heads/park and you have no current 'out' on the brown wire wire the H/L switch itself would be bad.. Being you hit a bump and lost heads AND park lamps, steers me towards the CJB and or its connector.
If you had no heads and park/run lamps,, I'd still check the F2.10, then at the H/L switch connector and finally at the multi function switch. You could also do a few pin point power distribution tests at the multi function switch so not to replace any good parts if that were the case..
LOVES VANS
May 5, 2015 05:04 PM
BilldarrAZ
Jun 30, 2014 08:25 PM
van driver
Feb 6, 2013 03:02 AM
crossroads
Sep 8, 2009 10:54 PM
okilexington
Nov 8, 2007 12:59 PM
