1998 E150 with p0401 code
Old Jun 17, 2015 | 09:32 AM
poster72's Avatar
Default 1998 E150 with p0401 code
Many thanks again to Hanky for the last help with my cylinder 5 misfire. Got that fixed but the other code i was getting returned. P0401 code. 4.6L Triton V8. 200k miles.
I see most recommend cleaning EGR vavle, possibly a dpfe something or other. Any chance i can get some advice on what to do here, where this thing even is?
Searching videos and see a lot for F150's but not sure that i would find it in the same place on my E150.
Old Jun 18, 2015 | 07:14 AM
You can get all the info I believe you are looking for at this site,
www,wells dpfe sensor.
Easy fix, go for it !
Old Jun 18, 2015 | 08:47 AM
poster72's Avatar
thanks...not sure if that was supposed to be a link or a general reference to this site?
www,wells?
Old Jun 18, 2015 | 08:51 AM
The correct site address is, www.wells electronics.com
Old Jul 10, 2015 | 11:58 AM
poster72's Avatar
man, i appreciate all the help Hanky, but i am kinda afraid to dive in to this one. Still not even sure where the EGR is and i couldnt find much on that site you offered. Maybe im not looking in the right place.
Tempted to bite the bullet and take it to a mechanic, but im being told up to $200 just to diagnose the 0401 code. Anyone got any more advice on where to start with this? I udnerstand it could be many things, not just possibly the EGR valve being clogged up.
Old Jul 10, 2015 | 07:11 PM
It never hurts to aquire as much info as possible before attempting what could be a simple procedure. There are sites that show what the part looks like plus what it does and what to watch for when replacing them. The DPFE sensor does use some hi temp hoses (short pieces) that if clogged or damaged would have to be replaced. If you get the parts together before starting the replacement , you should have everything you need to complete it without any surprises. You can do it ! The sensor is usually in an easy to get to location.
Old Jul 15, 2023 | 12:18 PM
PLForney's Avatar
I have the same issue. Pull the dog house EGR valve will be on the left (driver side) it sits up and back check YouTube there is videos on where to find the EGR valve. I'm a female and I found it pretty easily.
TYSONJR5
Jul 15, 2023 12:21 PM
fishfun83
Feb 19, 2009 04:14 AM
mrmush
Jul 30, 2008 08:24 PM
jcoast
Jun 18, 2008 02:23 PM
stone
Sep 3, 2006 03:50 AM
