1999 E250 Trans Filler Tube
Old Jan 16, 2026 | 09:58 AM
shaunryan62@outlook.com's Avatar
Default 1999 E250 Trans Filler Tube
I am having a real fight reinstalling this tube. And I seemed to have shoved the o-ring into the chamber, so a fluid drain coming soon.(After drilling out several blown spark plug ports) Are there any known alternatives such as the JEGS Flexible Braided Transmission Dipstick for Ford C6 [Polished].
Thanks in advance!
Old Jan 16, 2026 | 10:40 AM
If you drop the pan to get access to the loose "O" ring you might have a better view for installing that filler tube..
Did you have the doghouse cover off ?
Old Jan 16, 2026 | 10:44 AM
Doghouse and peripherals are removed. I think the tube must simply be wiggled in-no easy feat.
I will remove the pan soon. The view and access are excellent..the tube and ring are simply wildy difficult to reinsert..FORD somehow pressed this in..
Old Jan 17, 2026 | 09:08 AM
This might help,,,,,,,,,,,,,,,,,,usually that tube has a rib just above the bottom end where you have the "O" ring applied. If you get the tube in position, then with a long screwdriver or piece of wood, tap the rib down it should go in for you.
Old Jan 17, 2026 | 10:25 AM
I think the idea may be right..just above the inflated ring attach something for applied pressure-surely thats how it was done at the factory.
Jan 5, 2026 06:19 PM
JC333000
Jun 13, 2023 04:25 PM
Gabriel Sanchez
Jun 11, 2020 02:46 PM
cwowolf
Dec 28, 2008 10:44 AM
Doyle
Nov 29, 2005 02:18 AM
