2000 e150 4.6l highway RPMs
Old Aug 18, 2023 | 08:38 AM
rabies's Avatar
Default 2000 e150 4.6l highway RPMs
hello,
i have no tach in the van. maybe buy a cheap obd tach to see what I'm running?
i know its a van but mileage is sub optimal. 60k miles. new plugs/tires/chocks/tie rods/oil etc.
at highway speed (65) the RPMs seem pretty high around 2500-3000. overdrive button doesn't do anything, doesn't light up.
is this normal sound range? other than that. the van is like new. picked up it a month ago.
thanks
Old Aug 19, 2023 | 06:50 AM
Overdrive button doesn't lite up until you turn it off. Then it will say OFF.
Old Aug 24, 2023 | 02:23 PM
rabies's Avatar
so it could be stuck on. that wouldnt explain the higher rpms then. thanks
Old Aug 24, 2023 | 03:53 PM
The electrical part of the system may be working , but the overdrive parts in the trans may not be responding.
If the trans pan was dropped , you might be able to see something like a lock ring that came out allowing the overdrive piston not to work and maybe just sitting in the bottom of the pan..
CTP2022
Sep 17, 2022 11:06 AM
bigvanman
May 24, 2018 10:17 PM
dlbennett
Sep 2, 2016 10:36 PM
bobbydee
Jun 9, 2016 10:18 AM
tgolds
Apr 26, 2011 03:02 PM
