2006 E150 Steering Question
Old Sep 20, 2024 | 05:35 PM
Joedub1421's Avatar
Default 2006 E150 Steering Question
Hey guys, picked up a 06 e150 to convert into a camper. Now the repairs begin. First I need to is replace tie rods / ball joints.
Replacing everything from the tie rods, sleeves, drag link etc. I don't have the manual. And i'm seeing torque numbers all over the place on google. 55-75lbs seems to be the most thrown around. Can anyone give me accurate numbers? On the sleeves, drag link etc.
Old Sep 20, 2024 | 05:51 PM
Check my signature below. So it's 4.6L or 5.4L?
Old Sep 20, 2024 | 06:28 PM
Joedub1421's Avatar
My bad, was a quick post. 5.4L
Joe
Old Sep 20, 2024 | 07:06 PM
Old Sep 20, 2024 | 08:21 PM
Joe,
Just a reminder,
Don't forget to arrange to have a front end alignment done after replacing the tie rod ends.
There is also a recommendation of tightening the ball joints with the wheels straight ahead to prevent steering problems.
Little tips that make a big difference.
Usually , there is some tire wear indication when tie rod ends need replacement and toe needs to be right after new are installed.
Old Sep 20, 2024 | 08:48 PM
Joedub1421's Avatar
Awesome, appreciate it. Is that some web resource where you got the info from?
Yeah, I have a friend from home helping via Facebook Messenger and he mentioned that. I wish he were here, everything would've been fixed by now. Has every mechanic tool I could want lol. A few other issues I'll be posting. Appreciate the help. I'll probably do both ball joints and tie rods. Break pads if needed.
Old Sep 20, 2024 | 11:02 PM
Those are from my alldata software, any car make (not just ford) model from 1966 up to 2008. It's the dvd full version I got from where I used to work at. I converted them to disc images and mounted them as network drives.
alldata already switched to web based only since a decade ago. I prefer web based that's much easier to navigate when I can simply open as many new tabs as possible. The software based I can't even open multiple instance and I hate it so much, but it's better than nothing.
Look at the very first diagram I submitted previously, I posted that up on purpose so you can see and let me know what other diagrams you need from me.
Old Sep 20, 2024 | 11:06 PM
Joedub1421's Avatar
Appreciate it!
HemiRules2000
Mar 23, 2022 08:42 PM
HemiRules2000
Feb 27, 2022 03:14 PM
corrie
Nov 10, 2021 05:07 PM
Polly
Sep 26, 2015 07:08 PM
Polly
Aug 30, 2015 04:18 PM
