E250 - Can't get my o2 sensor readiness to complete
Old Feb 8, 2023 | 03:56 PM
  #21
diegob's Avatar
Both sensors are working. I suspect that the codes happened when I turned on the car without the sensors plugged in, so I could measure the voltage on the connectors. I reconnected them and I get the same readings from both of them as before, but I cannot get rid of the codes.
Old Feb 8, 2023 | 04:00 PM
  #22
aquanaut20's Avatar
The codes will not clear with heater circuit errors..
The sensors will work without the heaters, but will not satisfy the ECU..
Old Feb 8, 2023 | 04:18 PM
  #23
diegob's Avatar
The question I have is where did the errors come from, and what do I have to do to make them go away. Per someone else's suggestion I unplugged the sensors to test the voltage, and that's when the errors appeared from the first time. Nothing got damaged in the process, and I hadn't seen the errors before. Perhaps I should reset the computer?
Old Feb 8, 2023 | 05:27 PM
  #24
aquanaut20's Avatar
Reset the ECU so that we can start with a clear slate and see what comes back..
Your monitors will ALL reset to "NOT READY"
Old Feb 9, 2023 | 05:33 AM
  #25
We don't know the year of your vehicle.
Later models will not allow codes to be cleared with a tool or disconnecting the computer. The system MUST see that all is well for at least 2 cycles and the computer will then clear the code automatically.
Old Feb 13, 2023 | 10:31 AM
  #26
diegob's Avatar
It's a 2012. The codes did clear, and I'm back to everything ready except the O2 sensor and heater after 135 miles of driving. I wonder if there is anything I can do besides keep driving.
Old Feb 13, 2023 | 12:12 PM
  #27
Please clarify,
The codes did clear. Except,,,,,,,what does that mean?
Old Feb 13, 2023 | 01:58 PM
  #28
diegob's Avatar
Please clarify,
No codes. All emission monitors ready including evap, other than O2 heater and O2 sensor, just like before I unplugged them to check them. Some of the monitors hard reset to not ready after I unplugged the sensors.
Old Feb 13, 2023 | 02:51 PM
  #29
aquanaut20's Avatar
Not clear on your andwer,
Are you reporting,
EVAP,
O2 heaters and O2, are all not ready ?
Old Feb 13, 2023 | 04:30 PM
  #30
diegob's Avatar
EVAP is ready. The ONLY monitors that are not ready are O2 sensor and O2 sensor heater.
